Need Mem Buying Help
RoosterUSMC
Currently I have 2x 512 Kingston HyperX PC4000 CL3 in my P4C800-E DLX P4 3.2@3.67 and wondering if I should get some Corsair 3200XL 2225 or somthing like that.
If I bought some lower latency RAM how much of a performance increase would I get out of it and would it be worth the $250? Or should I just keep what I got? Or whats better RAM than the 3200XL, OCZ 3700 Gold REV2?
If I buy new RAM I will put it in my P4 machine but will eventually use it in my 939 Winchester in a few months and will want to overcock a few 100mhz.
Thanks
OCZ Platinum Rev2 PC3200 CAS2 also has 2-2-2-5 timings. i would go for this or the corsair.
If you got Corsair or OCZ 2-2-2-5 with your current setup, you'd have to run the ram at a divider (read: lower speeds) to keep the 2-2-2-5 timings. This would actually lower your performance, because pc3200 @2-2-2-5 is not faster than pc4000 @ 3-4-4-8. Also, running your ram on a divider lowers performance by itself.
a higher clock speed is always better than tighter timminga at lower speeds. keep your pc4000 and you should be able to tighten those timings on a lower speed. you dont really need to spend the extra money for better latencies since you have good ram in the first place.
