TechLarry
RIP [H] Brother - June 1, 2022
- Aug 9, 2005
I need a Macro Program that will record what I do in a Web Form, then replay those actions when called up.
It must be able to:
I basically want to hit record, fill out the form as needed, hit stop and save the Macro. I don't have time for manual programming...
I use PhraseExpress for basic macro expansion, but it's not designed to move itself around web pages, select choices from pop-up menu's, etc... Great little utility, but I need more.
It must be able to:
- Repeat text that I type in
- Select and change several pop-up selectors on the web page
- Enable/disable check boxes, etc...
