Need low profile heatsink....
rbarr110
I need a low profile, but extremely quiet heatsink for my HTPC case. I would love to go fanless, but I don't think I can find a heatsink small enought to fit in my case and cool an Athlon 2000+ CPU.
This is the case I have:
http://evercase.com/newsite/2product/gc1290.htm
They have an accessories section with a low profile fan, but they charge way to much for the heatsink. It is almost is the same price as the case.
Any suggestions?
Sorry for double post, getting proxy errors and accidentally submitted twice.
You could definitely put more than a 1u in that case. With a little squeezing, I could fit a zalman 3100 in a low profile case. You could easily take a large alpha or swiftech heatsink and simply duct it to another fan in the case or put a 60mm fan on it blowing sideways. be creative! Those 1u heatsinks are very loud and dont cool as well as you might hope.
Sorry, I left out a bit of important information, I am using a 90 degree PCI adapter for my Hauppauge 350 tuner/encoder. The PCI card invades on the space for the cpu/fan. I currently have a Thermaltake which is approximately 1 3/4" tall and is about 1/8" too tall and touches the pci card and causes excess noise due to the "cavitation" because the PCI card is so close.
I currently put a rubber spacer on the edge of the fan and PCI card to reduce cavitation noise. I am thinking about using a 1U cooler but really want a quiet one, or maybe a cooler where the fan mounts on the side of the heatsink. Once again quiet/silent is the goal.
Thanks
