i want to replace my rear fan, enlarge my front fan, and get a fan for a heat sink for my cpu. all 120mm. idk if the same fan will work for all 3 purposes or if i should get different types. unlike most people, i dont mind a high noise level. ive been sleeping with my case sounding like a v8 for 3 years. its hard to sleep without it now. i figure that means i can get a higher cfm for a lower price than all the low-noise ones that are recommended everywhere. anyone have cheap cheap loudish fans they like? newegg reviews are so hard to go by, and there might be good deals on other sites that im not finding. thanks all!
as long as were on the topic, i want a cpu heat sink. i thinking the s-1283 since it has a rebate and free shipping (thanks [H]) this week. how much of an oc can i get with an e6600 and the specs in my sig?
