Hiya,
Some very good friends of mine have a brand spanking new laptop. I made sure said laptop had a wireless n card built in when they bought it. Now they want to use the laptop in their house away from their router. The router in question is in their office which is detached from their house (about 80 yards away with some trees inbetween). Their current "g" router is not cutting it, it didn't work at all when the leaves were on the trees and now that the weather has turned cold its performance has improved to the point where it can be called "spotty."
So I'm thinking a wireless n router is the way to go. But as I explained to a friend of mine choosing one of these devils is a bit like trying to choose which goat will chew up your rose garden. I mean, who knows what to look for in a goat, and regardless which one you pick the outcome will be less then desirable. I think I might be better off with a 5ghz router some of which can be had for around $100. If I can get away with less then that I'm more then happy to shoot for it.
Any advice would be greatly appreciated.
