Need Latency tracking tool recommendations.
Hey Everyone,
My company is looking for a tool that is based off of Tracert, but will do multiple traces on the same exact path, and either graph or keep some form of metric on that trace, so we can start diagnosing when routes and or single routers are causing issues for our applications. Currently we use a tool called winMTR that is very unreliable, but in the past has proved somewhat useful. We have taken a look at another tool called pingplotter and it is definitely a nicer front end, with some great graphing plug-ins and you can setup the amount of tests to run for a extended test to see how much packet loss you have.
This is more or less what we are looking for. Money isn't really an object, we just really need a tool that will work for us!
Please any recommendations you have I will definitely take a look at! Please link to the software if possible.
Thanks!
