Hello all, I'm in need of your input on a complete new build. My last system was built around a Q6600 overclocked to 3.6ghz. I was about to do an upgrade with it when someone offered to buy it rather than have me build a new system for them. I decided to take that offer and do a new build for myself.
Audio/Video encoding, backing up dvd's & BD etc..Archiving Vinyl, Photoshop, Premiere, web browsing, maybe gaming?
No set budget being I'll be gathering parts here and there so I have time to get what I want.
3) Where do you live?
Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
PSU, Motherboard, cpu, Memory, cooling, video card
HDD: 2x WD 1TB WD1001FALLS (fairly new removed from last system)
6) Will you be overclocking?
Yes
24" NEC LCD2490WUXI (NOT WUXI2)
I've already started gathering parts as they go on sale.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Plan to overclock this system. More than likely I'll be using raid. Not sure whether I'll be using CF or SLI at this point. Wouldn't mind having it in the event I decide to use it in the future.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Windows 7 Ultimate 64 bit
At this point I have a fair idea of what I want. The main things I need input on are the cpu, memory and video card. Here's what I'm thinking of thus far:
Case: Thermaltake Mozart TX (Have it)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133027&Tpk=mozart tx
PSU: Antec TPQ-1200
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16817371032
Motherboard: Asus R3E
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16813131642
CPU: i7 980x
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16819115223
OR
i7 930 (Being I'll be overclocking I will take a 920 providing I can find one)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225&cm_re=i7_930-_-19-115-225-_-Product
Cooler: Hmm Not sure of this one. I read of a lot of coolers blocking the ram slot closest to the cpu. Cold use your input for sure on this one. Also considering going liquid cooling being I have the Mozart TX case. It'll be my first time going liquid but certainly not afraid of trying.
Memory: Corsair DOMINATOR-GT Model CMG6GX3M3A2000C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145255&Tpk=CMG6GX3M3A2000C8
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226100&cm_re=998776-_-20-226-100-_-Product
DVD: Sony DRU870S (Same as AD7240S)
http://www.newegg.com/Product/Produ...7118030&cm_re=sony_dvd-_-27-118-030-_-Product
Video Card: EVGA GTX 470
http://www.newegg.com/Product/Produ...550&cm_re=evga_gtx_470-_-14-130-550-_-Product
OR
EVGA GTX 260 ( I see this SC version and reg. version are nearly same in price..had this in my last system)
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16814130433
As a rule I'm NOT one to replace my system on a regualr basis. There is no such thing as future proofing, as such, but I figured if I were to pull the plug on the 980x it wold allow me to keep it for some time being not all software will utalize all 6 cores at this time. With this in mind would it still be worth it for audio/video work or should I cheap out and just get a 920 or 930?
Regarding the memory, should I go for the Corsair( same models as shown but with CL7) or opt for the Muskin? One has tighter timings but with the Muskin it'll allow for up to 24 gigs where as the Corsair will only permit 12 gigs. Then again, I can't forsee me using anything more than 12 gigs at this point but with the Corsair it'll limit the amount of ram for future expansion.
I had no problem(s) with the GTX-260 in my last build. I'm just wondering if the GTX-470 would be way overkill in the event I won't be gaming? It'll certainly allow more options being a newer card. HDMI for tv hookup comes to mind. However for video work would I be better off going with the 260 and upgrade to the 470 down the road if required?
It's getting late. Nearly forgot the hard drives. I'll more than likely be using the WD TB drives from my last system. I may just keep them as is being I do have data on them. I've also been toying with the idea of purchasing either their new(er) 1TB or 2TB drives as well. I also have a new Intel 80gb SSD, that was meant to be installed in my old system, but the guy bought it while the drive was being shipped. Anyway, it'll be used for the OS and apps. Thank you in advance for your input.
Canada
Yes
PSU: Antec TPQ-1200
CPU: i7 980x
OR
OR
OR
