Need input on new watercooling system and component selection..
Tomash
I'm putting a 540mm radiator in that case, and the whole system (eventualy there will be another GPU in there) will be running off of it, of a single, split reservoir, with dual pump for redundancy.
Is there anything you'd change? And why?
Reservoir:
XSPC Acrylic Dual Buy Reservoir for Two Laing DDC
Pumps:
Swiftech MCP35X - two
VGA Block:
Koolance VID-AR797
CPU Block:
EK Supreme HF Universal
Radiator:
Magicool 180 Slim Radiator 3x180mm
Tubing:
PrimoChill PrimoFlex PRO LRT 3/8"x5/8", Black
Fittings:
Lamptron Elite 5/8" Clamp, Black
Enzotech High Flow 3/8" Barb, Black
Enzotech 30/60/90 Degree Rotary Fittings 3/8", Barb, Black
Enzotech G1/4"-T Block, Black
Enzotech Drain Plug 3/8" Barb, Black
Enzotech Male to Female G1/4 Threaded Adapter
Koolance QDC (High Flow), G1/4, Male
Koolance QDC (High Flow), G1/4, Female
Enzotech Male to Male G1/4 Threaded Coupler
CPU:
Intel Core i7-3930K
Motherboard:
ASRock X79 Extreme 9
RAM:
CORSAIR Vengeance 32GB (2x 4x4GB) DDR3 1600
Storage:
Crucial M4 256GB
WD Black 640GB
GPU:
Sapphire HD7970
PSU:
Seasonic Platinum-1000 1000W
Case:
Silverstone FT02B
OTHER STUFF:
MDPC Sleeve Kit
MDPC Sleeve, Small, Titanium Grey
MDPC Sleeve, Small, Grey
MDPC Sleeve, Tubing, Black
Dual Ended Universal Molex Removal Tool
Cable clamps small medium large
Silver Coil
XSPC LCD Temperature Sensor - White Backlight - two
XSPC Drive Bay Display Frame
Bitspower G1/4 Temperature Sensor, Black
Phobya HeGrease Extreme Thermal Paste
ModMyToys Shouldered Thumbscrews, Black, 10
Logisys Light Bar, 20", White
Phobya Terminal Strip, Black, 16mm/5/8", 6 clips
General Tools 1" Magnetic Strip, 10’
Phobya 90° Tubing Mount - 5/8"
Phobya Tubing Holder 5/8"
PrimoChill Anti-Kink Coils - 5/8", Black
