Need info on KVM's
Chakachim
Where I work we each have to computers. Each computer has its own monitor, but we would like to split the keyboard and mouse between them. We currently just use regular KVM's to do the job, but we need to switch to usb so they are buying new ones. My question is, Do they make a "KVM" that doesnt use a key combo to switch machines. What we want is almost like a dual monitor setup, where we can just move our mouse off the right side of the screen and it switch to the other machine automatically?
Yeah, I was looking at synergy, but unfortunately thats not an option. One of the PC's is corporate network, which we can not add ANY software too. Is that the only option?
If so, what normal KVMs do you guys recommend, we need one that is fairly easy to switch, we currently have to hit left-ctrl + backspace. which sux cause we switch about 200 time per day.
I've seen some older Belkin KVM's that you can bind the scroll lock key to... tap it twice and your switched. Don't have a model number for you though... sorry.
And O do not know of any hardware KVM that will work like Synergy does....
