need info and help on molex cables
decade146
this switch is powered by a 4 pin molex. it converts into a 2 pin that is sent to an inverter which then goes to my uv cathode. Id like to make it more compact by removing making it so theres less wiring. one black and one yellow wire from the 4 pin power molex (on the right) go to the switch. All i want is to power the cathode and dont care about powering another thing with a 4pin molex. Anyways the black cable goes to the 2 pin that connects to the inverter. the yellow wire connects to the switch and then changes to a red. this is where im concerned as if i just cut them and connect them i think i might get the wrong voltages. all i would like to do is power up to the 2 pin inverter from a 4 pin molex. would it be correct if i cut the start and end wires and connect black with black and red from the 2 pin with yellow from the 4 pin and heatshrink them? thanks :D
what? got a diagram? lol
don't mind the colors, as long as the wires are being reattached to (essentially) the "same" wires after the trim.
