Need Ideas
madel
Bad Trader
My current case is a Lian-Li PC65-B
I'm trying to design a setup for watercooling. I want to put a radiator in it, and this case is relatively small. Can anyone recommend some small radiators that work great.
Ive seen pictures of people with the same case as mine, or close to it from Lian Li. Im torn whether I want to attempt to attach the radiator up top under the intake fan on the ceiling of the case, or just put it up front in the bottom (assuming it is small enough to fit). I would honestly rather put it up front, but I am open to opinions.
SHOW ME SOME RADIATORS
I've got you covered on this one.
A Black Ice Xtreme radiator fits perfectly under the 3.5 drive cage if you take out the HDD rack, mount, and move the speaker. Here are some pics of my BIX that I stuck right up against my 2 intake fans.
Hope this helps.
-OMP
Damn dude, that is exactly what I needed :)
Thnx your one in a million. ^_^
I'm having the same prob. I also have a Lian Li PC65-B and have no idea where to put my rad. Only diff with me is that my drive cage currently has 4 120gB WD HDS in it, so I cant remove it and put the rad at the bottom :(
