Charles W. Stumpfel
- Sep 11, 2007
I'm trying to get my new raid 5 array happy before i start dumping gig after gig onto it.
Hardware:
Gigabyte ga-p35-ds3r
q6600
3 WD 500gig AAKS Drives - miserable in RAID 5
2 WD 74gig Raptors - Happy in raid 0 (128k stripe)
I want both arrays on the ICH9R. The problem is i can't get the RAID 5 to perform acceptably. The first go around i tried a 64k stripe size and 4k cluster size. Ran hdtach(i know its a poor benchmark for raid 5...) and got poor seq read ,67MB/s. So i figured i'd re-do the whole thing after doing some research and tried 32k stripe and 64k cluster. Well reran hdtach and got 55MB/s read. Said to myself, screw it, im sticking with this set-up. Starting copying roughly 100GB of data(100k-1gb media) onto the array. 2 hours later it was only 1/3 copying and i canceled it. Was getting roughly......10-15mb/s write speed from what i can tell. And from what i can tell WB cache was enabled.
I'd like this to be my final re-do. Its going to be a media only drive with files ranging from 100k-5gb. I've found too many conflicting theories on the net about cluster/stripe ratios and whether large sequential files need big/small stripe sizes. My next try was going to be 128k stripe with either 4k cluster or 64k cluster.
Any input would be hugely appreciated considering it takes several hours to re-format/test each of these set-ups.
Thanks in advance,
chuck
Hardware:
q6600
Thanks in advance,
chuck
