rapperwith1p
- Oct 23, 2005
Hey guys I've decided to wait on Conroe for wide availability and am going to overclock my P4 630 to get as much out of it as I can. Right now I'm using the stock Intel HSF overclocked from 3.0ghz to 3.22ghz 214 x 15 at 1.4v. I can't go much higher as it won't post and it's a PITA to reset the jumper on the cmos to get it to default settings. My idle temps are mid to high 40c and max load is anywhere from high 60c to mid 70c and I want to push it to at least 3.4ghz. I have a Coolermaster Wavemaster that has a 90mm exhaust fan in the back and am using a MSI 945g mobo and need recommendations on a good aftermarket hsf combo. I was looking at the selections from Scythe such as the Scythe Mine and the Scythe Ninja which have good reviews but look enormous. I don't know if it'll fit my case. Judging from the case and mobo I just mentioned do you think I can fit one of those monsters in there? Or if not then what would you guys recommend to get me to 3.4 possibly without breaking a sweat and leaving voltage where it is at right now.
