Need HSF Advice for E4300 for <$30
SparksNelec
I plan to OC a E4300 to DDR800 speeds and I'm pretty sure the stock heat sink can cool well enough for that. But I wanted to know if there are any HSF's out there that can perform significantly better than the stock HSF that comes with the E4300 for less than $30? I know many can cool more quietly, but if none of them can significantly reduce temps from what the stock cooler can do, then I'll just deal with the higher noise and heat and stick with the stock cooler.
Thanks.
