Heliocentrical
- Mar 28, 2005
I've set up tons of small networks with shared printers, mapped drives, broadband ect.
I'm no whiz by any means but I know how to follow instructions
The question I have is about a small network I was recently asked to maintain. The network consists of two dell workstations, one network laser printer and an external network hard drive for backups. They are connected to router which also provides web access. There are two issues:
1)The network is only running at 10mbps which makes data backups painfully slow.
2) The internet connection is extremely slow. I tested the speed several times and it averaged 128kbps.
The install was done about 3 years ago. Shouldnt the router and nics be 100mbps capable? What kind of broadband runs at 128kbps? ISDN? Why in the world would you use that? Aside from that, when tracing the cat5 cable running into the cieling I found the telephone wire was spliced directly into an ethernet cable. No adapter..Just a bunch of tiny exposed wires twisted together without tape, clips or fasteners of any kind. I've never seen something like this and dont even know where to start. Advice or comments?
