Need help
I'm new to amd 64.I just put my system together.Where should I start at.I mean overclocking.The motherboard is a MSI K8N NEO2 Platinum.I have AMD Athlon 64 3700+ San Diego 1GHz FSB 1MB L2 Cache Socket 939 Processor and OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Platinum System Memory.I will be buying the OCZ PC4000EB Platinum Edition memory in a month or so.I know I won't get far with this memory. My cpu coolers a ZALMAN CNPS9500 LED 92mm 2 Ball Blue LED Light Cooling Fan/Heatsink.Right now I'm at stock speeds.Thanks for your help. :)
