need help
nd2
im having a bit of troble getting my Tbird 1.2 b running on my EPoX EP-8KTA+ mother board, at the moment it boots but when scan disk or windows loads it crashes in to a garbled screen i think the problem is the vio core settings which i left as is they are set at just 3.4v which is the lowest setting which i used for my duron 700 does any one know the correct settings for this tbird processor?
sounds like its an operating system problem, or one of many other problems. what makes you think its the cpu?
I think that's the longest sentence I've ever seen...
