Oct 12, 2012 #1 L Legion- Weaksauce Joined Sep 19, 2012 Messages 98 I plan to use water cooled setup for my new rig ( specs in sig). I plan to TEC the cpu and water the gpu's. Need some ideas about parts. Any advice will be greatly appreciated.
Oct 12, 2012 #2 L Legion- Weaksauce Joined Sep 19, 2012 Messages 98 Oh and will cooling the gpu's hurt the heat dissapation of the hot side of the TEC?
Oct 12, 2012 #3 Tsumi [H]F Junkie 2FA Joined Mar 18, 2010 Messages 14,487 Don't bother with a TEC. Notoriously inefficient. Just go with more radiator area. Read the stickies. Then post exactly what you plan to do and what you need help with.
Oct 12, 2012 #4 A AP2 [H]ard|Gawd 2FA Joined Jun 25, 2007 Messages 1,570 Listen to Tsumi! He knows what he's talking about.
