Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I bought a corsair 700watt psu for my antec sonata 3 case, but the screw holes on the psu doesnt match my case... Anyone know specific psu's that will fit on my antec sonata 3 case?
That was meant in all seriousness. Most cases have holes that are designed to mount the PSU in both orientations. Some are designed for only one orientation. PSU mounting holes are standardized, I'm not sure why you are having trouble.
