My current system.
AMD Phenom II X4 965 Black Edition
Prolimatech Megahalems Rev B
ASUS Crosshair III Formula AM3 AMD 790FX ATX
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel
750 watt pc power and cooling power supply
150 gig raptor hard drive
Sapphire vapor-x 5870
Windows 7 64-bit Ultimate
System specs
FSB frequency: 200
DRAM frequency: 1600mhz
CPU NB: frequency 2600mhz
HT link speed: 2000mhz
CPU: 1.375v
CPU NB: 1.35v
Dram: 1.55v
NB: 1.25v
SB: 1.2v
HT:1.4v
Timings: 9-9-9-24 @ 1.55v
core speed: 3.6ghz
multiplier: x18.0
bus speed: 200mhz
Ok so basically with the above settings, I am Prime95 stable for 8 hours. (haven't tested longer). My goal is to hit 4.0ghz and right now i'm at 3.6. I tried to hit 3.8 by setting the multiplier to x19, but about 5 seconds into prime95, I get a blue screen that was telling me it was dumping physical memory. What i'd like to know is what can I lower/raise on my current bios settings to be able to hit 3.8, then 4.0ghz stable? I'm still fairly new to overclocking and could use some help. Thanks.
System specs
FSB frequency: 200
CPU: 1.375v
CPU NB: 1.35v
Dram: 1.55v
NB: 1.25v
SB: 1.2v
HT:1.4v
core speed: 3.6ghz
multiplier: x18.0
bus speed: 200mhz
