Need help
I just installed a new power supply and bought a 9800 gtx + which I also installed. It came with Cod5. My problem is that the game only shows up in my drive half the time. So I can't play it. I'm not sure what to do/try.
thanks
Have you tried updating the firmware on your optical drive? Patching the game to its latest version (without requiring the need of a disc)?
When I struggle to get disks to work, I smear dish washing liquid on them while running water over them from the tap.
Make sure every last bit of the liquid is washed away.
Then dab them dry with a towel, taking care not to scratch the disk.
Failing that, it sounds like a faulty disk or drive (possibly in need of a firmware update)
Do other disks work ok with a similar amount of data on them?
Can you try another drive?
drive firmware update fixed it thanks. Being new to vista, is there any reason why the game doesnt show up under all programs?
