NEED HELP!!
hk09
HI. This is my first time build a computer. I am trying to connect the wire (ie. LED). I can't figure out which side is + or -. I only saw s, g on back of wire... PLZ help
The positive wire is typically the colored wire, but not always. There should be an arrow on the tip of the connector (of the wire connected to the case). This arrow indicates the positive lead.
Yea. I saw a triangle on one side and that mean that side is positive? Thank you
worst comes to worst just trial and error. your chance aremt that bad... 50/50 lol
one more question.... I have 1394 wire. Where do I suppose to plug in the M/B?
There should literally be a 4 pin connector on the bottom right of the m/b that says 1394.
