need help
vinceboi
how do i fix this?
It is trying to load the nVidia control panel. Try re-installing the drivers.
Use Driver Cleaner to get rid of your drivers, then install the latest release.
well ic ant re-install the nvidia drivers cuz im not usin nvidia card anymore, and do i have to uninstall my omega drivers and do a driver cleaner den install again? cuz i already did the cleaning but it still pops up
You should use Driver Cleaner to take them out. If you do not want to do that goto your start button and choose run. Then type 'msconfig' goto startup and uncheck anything that has nv- outside of it. This will take away the error. You really need to clean up the old drivers as they may cause issues later.
Use Driver Cleaner and set it to clean all ATI and nVidia drivers, then reinstall the Omegas from scratch.
