I just got a new motherboard, the Abit AN7 Guru. I'm using that with default settings along with a 2500 Barton and 512 DDR 2700 Kingston memory. When I pick load windows normally from the menu the screen goes black and stays there. I tried loading linux up but it freezes at "Configuring Kernel Parameters." These are both on separate hard drives.
I have swapped out the CPU for an XP 2400 and get the same results. I've also swapped out the memory with Corsair and a Generic DDR 2700 Chip. Still no go. I've also tried doing a fresh install of Windows XP from the CD. It freezes before the menu comes up.
I did run MemTest without fail, the memory checked out okay and the program ran fine.
Any help would be greatly appreciated, I'm about to send this board back. I don't know what I am doing wrong!
Thanks
Thanks
