Abula
- Oct 29, 2004
Hi,
I just build a new PC,
Motherboard: Asrock Z370 Taichi and Z370 Killer SLI/AC
CPU: Intel i7 8700K (delided)
Memory: GSkill trident RGB 32GB DDR4 3200 CL14
SSD: Samsung 850 Pro 1TB
HDD: WD RED 3TB
OS: Windows 10 Home 64bit
The problem that i have is that sometimes i lose control on the PC, like a hickup or a temprary freeze (5 sec or so), like if its going to crash but the it comes back. I first decided to change mobo, i had another issue with the SLI killer so decided to upgrade toward the Taichi, but it has the same problem, so its not the motherboard or less likely. Temps are fine, idle around 30C and load 65C the most i seen, atm the CPU is not overclocked, and the mobos are on the latest bios.
I tried to check with DPC Latency Checker v1.4, and while it seems high on 1k range, its the same with my laptop and another pc, although on my threadripper build it goes down to 500, i still not sure if its hardware issue or software issue or a bios setting, maybe you guys can give me suggestions into what to try.
Thanks for your time,
HDD: WD RED 3TB
