coolrunner84
- Sep 5, 2008
I have a few problems with WHS, that I am hoping people can help me resolve. Since WHS is such a hit here, maybe more people here would have experience with it and have come across some of these issues.
Note: The only change I have done to my system is that I bought a new switch (HP 1800-24g). The server has all the latest updates installed.
1. On Christmas, I had some family over, and we decided to watch a movie from my server. At some points of the movie, the video and audio began to stutter. It would eventually correct itself after 20 seconds, but I was a little embarrassed. At first, I though it was just the extender (Popcorn Hour A-110) since it was a blu-ray video, but last night it happened again through my HTPC. I am clueless as to what the cause can be. Disk Management does not show any disk as unhealthy.
To me it appeared as though the drive was being written to, which caused it to stutter. However, I am the only one that writes to the server in the house, which I was not doing at the time these occurred. The majority of my drives are 1TB WD green drives which are only 5400 rpm and have a 16MB cache. Could this explain it? What was WHS doing that caused this to happen?
2. When WHS came out, I remember reading about the auto-balancing feature, where the content would be distributed evenly across all the HDDs. After I installed the Disk Management Add-In, I can see this is not the case. All my content is going to only 3 out 8 of my drives. Is anyone else seeing this?
3. I want to build a Wireframe with the Disk Management Add-in, but I cannot identify where the disk is located in the server. The serial number does not appear in Disk Management. The only descriptive thing it gives me is the GUID (e.g. 8f7cdce0). What does the GUID represent?
While creating the wire frame, the "Drive Path" gives the port ID, e.g. 2:1:1:0. How can I determine which port the drive is connected to?
4. Has anyone used the Remote Access feature of WHS? I can connect to my WHS outside my home, and browse the shares. However, when I try to connect to a client PC, it always tells me that the connection timed out. Has anyone been successful with remoting into their client PC using WHS?
Thanks in advance for any help you can give me.
