Flintblade
- Jul 2, 2006
Ok, so I've always wanted to build a Watercooling unit. Air cooling is good, but not as efficient as watercooling and also no dust. But I've always been confused with how watercooling works and how to determine what parts are better then others. Or how to find out if a part is even reliable or better then air cooling. So I did a little research and i'm a bit more familiar with Watercooling, but I still don't know enough. What I have gathered so far is...
The pump:
The pump is the part of the watercooling kit, that obviously pumps water. The faster it pumps the water, the cooler the cpu or video card will be. So obviously a pump that pushes 90L/H should be better then a pump that pushes 400L/H. But what else is there to know?. Like if two pumps can push the same amount of water per hour, how do you know which pump is better. Also, could it be possible that a pump that pushes 400L/H be better then one that does 600L/H just because of the design etc.
The radiator:
So the radiator draws the heat from the water, and then the fans cool the water down. So, technically speaking, wouldn't a radiator that has 3x 12cm fans be better then a radiator with 1x 12cm fans. Or is it possible to get a radiator that has 1x12cm fan thats better then a 3x12cm fan rad. So how else would you grade a radiator. What else does it have that you can look at to see if its good or crap. Like if the radiator is made from certain material that conducts heat faster or something like that.
The reservoir:
So from what I've read, a reservoir just stores extra water for just in case purposes. So is there anything to really look at with a reservoir. Or does it not matter, and just go with what you can afford or what holds the most water.
The waterblocks:
A waterblock is like a passive cooling heatsink, with the watercooling adjustments. I have no idea on which waterblock to buy, because I don't know what to look for. Is it like a heatsink at all, where copper is better then alluminum, and a clear surface is better then a scratched surface. Is there anything else to look for?
I think that just about covers everything I would like to know. For those of you that take the time to answer my questions, thanks! =D.
P.S: Yes I am a noob, thats why I came to these forums to ask the experts. I've been doing lots of googling already but nothing beats asking a person that knows a ton about the topic =D
The pump:
The radiator:
The reservoir:
The waterblocks:
