need help with video card
Bman123
I don't know if you can use any video card or not so here is the mobo I have in my pc
http://www.ascendtech.us/itemdesc.asp?ic=MB64GWMCP61PM2M&eq=&Tp=
I know it is a factory mobo but I am not interested in buying a new one.Bad enough I have to get a new PSU.So can I use an nvidia video card like an 9600gt or an 8800gt?If so does it need to be a certain MFG card or not?
I also know it isn't a 2.0 pci slot but it is a 16x slot.
As long as the cards you mentioned will physically fit inside your case, they will work. You do need to make sure you have a six pin PCI-E connector as well. Power requirements will have to be considered too, but you mentioned a new PSU. What kind of PSU are you thinking about purchasing?
You'll also have to disable the onboard video. It could be a jumper on the motherboard or a setting in the BIOS.
he wont have to do anything but disable the onboard graphics in the device manager. the settings in the BIOS for Gateway/Emachines is already set to recognize a vid card once installed.
OP what are the rest of your specs? if you get a cheap 8600gt then you wont have to get a new psu. the 8600gt would be a massive leap in performance over the 6150.
I have a 17in lcd monitor at 1280x720
I also have a 32inch lcd tv that is 720p that I can play on aswell as long as the ole lady is at work
What should I get to play on these screens?
that psu has some negative reviews.
Is there anything wrong with the ones I have selected that I put in my post?
Again, just make sure this stuff will fit in your case. The Corsair 450VX gets my vote along with the 8800GT.
well you acted you didnt want to spend money on a power supply. I would get the Corsair 450 watt psu and a 9600gt since you are playing at 1280x720. BTW I dont see how you play games on that tiny little 17inch widescreen monitor.
most of the time I will be on the 32inch tv except when the ole lady is home.I wil have around 3-4hrs a day on the 32inch tv so I doubt if I'll be on the 17 much at all.
I am gonna purchase a 22inch but that will be next year or later since the 32inch will hold me over.
We have the same system specs cannondale.
I see you have a 8600gt,what size monitor do you have and what games do you play?
How much wattage do I need to run everything?I don't know what a system takes to run,I do know my pc has a 300watt psu but that isn't gonna be enough.
Also what is a good cheap mobo for my cpu that is SLI and hold 4 gigs of ram
Well I still use an old crt so try not to laugh. My HP pc only has a 300watt psu with 19amps on the 12V buts its ok for my little setup. My system has never pulled over 200watts at full system load. I play all the major fps games and Crysis and Call of Juarez in DX10 are the only games I cant max out at 1024x768 or 1280x960.
That Corsair 450 watt psu would be a really good choice no matter what card you get. You would have plenty of room to spare even with a 9800gtx. You might run into some cooling issues with your case though but the 9800gtx does exhaust air out of the case so that helps. I installed a front fan and it lowered my temps significantly because my 8600gt was dumping its heat right into the case.
