Need help with upgrade choices...
dpaul01
I'm currently running a 1.1 Athlon w/640MB ram and a 9600xt ATI. I OC to 1.3ish and I'm finally ready to upgrade. I've always waiting for big major upgrades, but I'm thinking otherwise this time. Why spend $2k at once and have a system that's top of the line for 6 minutes, overpay for it and then wait again for 2 years or more? I can upgrade over time, spend the same $2k but have a system that'll perform very well (but not the best) at all times.
I'm going to upgrade my box now, with 2 choices: I will keep existing 9600xt I just bought either way. I have an existing Antec case that is awesome, and I'll keep my other components (which are good) for now.
AMD XP
2500+ Mobile
Abit Nf7-s
512MB 3200 DDR (2x256)
Therm 12 HSF
Antec True430 PSU (or less)
COST is $396
AMD64
AMD 64 3000+
ASUS VIA K8T800
Buffalo Technology 512MB DDR PC-3200 (1x512)
Antec 430 PSU again
Keep stock HSF for now
COST is $545
Is it me or is there a huge difference in performance for $150? yeah yeah, I know all about 939 and PCI-Express et al., but by the time its worth buying these things, another year has passed. I can get 1 1/2+ years from this rig by upgrading memory, going SATA, new vid card and new CPU, for a lot less than buying a top of the line rig end of this year.
Thinking about Athlon64 3200+ also, but theres a jump inprice there. Also open to best mobo memory combos for the 64 as I'm not married to either of them.
Originally posted by blackrino9
what do you use your box for or want to use the box for?
ditto.
If you have the money the AMD64 is probably a better long term investment. Either one of those setups looks pretty solid though.
EDIT: welcome to [H] !!
I had a Athlon XP 2500+ system like yours and upgraded to an Athlon 64 3200+ and the increase in performance is amazing. I installed Windows XP in under 15 minutes. I would highly recommend the Athlon 64 system.
~N
