Need help with temps
Bleedblue12345
My temps seem quite high, yet ive been running like this for 1.5 years... need some help in lowering them...
Here's a pic...
I have an 80mm blowing right on it and the case has good airflow... im thinking I need to reseat and check the cooler... im using stock btw... any help?
on a 7900gs
i have a gateway so i can only use stock cooler..... (long story with this purchase, my new q6600 machine kicks its nuts)
Holy crap!!! That is the highest temperature I have ever seen!!!! Stop using it, take it out and reseat the cooler with AS5 or get a aftermarket cooler. To me, 90C is way hot too. But man, 127! I am surprised your pc didnt shutdown or your monitor didnt turn off yet.
Took it out, I used my newly arrived artic silver thermal cleaner to take off the vmod on the card (for my 8800gt and acelero s1 v2)...
OMG the thing was a mess.. the shit was over like 4 voltage pins.. i can't even imagine what that thing was running at......
Now it loads 85-90C, which is much more reasonable...
I was running at that temple for 6-7 months atleast :rolleyes:
Do i win max gpu temp competition :D
BTW I HIT 129 degress Celcius, 1C off thermal shutdown temp :)
:eek::eek::eek:
clean the fan, reapply thermal paste, get an accelero s1
QFT. ... My 7900gs was up in the 80s but then I got a S1 (now load temp is 40). But if you cant do an S1, you'll just have to try what master pain said.
