Need help with streaming audio recording
gcapp
Hopefully someone can help me with my hardware issues and using online streaming recording software.
I have a HP desktop pc with Windows 7 Pro (64 bit). When I go to Recording Devices the only item listed is Digital Audio (S/PDIF). So when I go to use Audacity or Replay 5 and try to record streaming audio, I get input from the left channel only. And it isn't even the music I am trying to record. It is a constant noise (buzz).
So.........................
I bought an Asus Xonar DX sound card and installed it. It works fine. However, again when I go Recording Devices, the only options are again Digital Audio (S/PDIF) or Line in. So again Audacity or Replay 5 doesn't work correctly.
I noticed on my laptop that it has IDT High Defintion Audio which does allow recording with Audacity or Replay 5 correctly.
Does anyone have any suggestions?? It's as if I don't have the correct hardware to allow any streaming.
Any help would be appreciated. Thank you
