Need help with some GPU's
D-30-P
So basically, I have about 6 mining rigs as of now. The issue I have is that I have a GPU that used to work (got about 22 mh/s out of it , while mining ETH Classic) but now it's giving me 2 mh/s ? I have tried multiple different cards which are the exact same and I'm still getting the same issue. I also purchased another make of GPU's that should be giving me around the same (20 mh/s) but are only giving me 1/2 mh/s which I know is not correct.
I have tried everything, updated to the latest windows with all the updates, latest drivers, different riser cables, complete re-install multiple times, uninstall and reinstall the drivers of those cards that arent working... If anyone knows a solution please could you let me know, thank you !
Currently running on 64 bit Windows 10.
Might be worth booting up in Linux and seeing if you get better results. Even if you don't want to use Linux full time, it can at least let you know if something is wrong with your hardware (such as on the motherboard).
I've been using Ubuntu on my mining rig and it seems to work pretty solid. Otherwise it could be a BIOS setting or issue. I had to change a bunch of settings in BIOS to get my rig working, it's possible the BIOS got reset. It may be worth updating BIOS and double-checking the settings.
