Need help with Smartfan
sitheris
Ok I figured out that Temp1 was CPU so I relabeled that.
Temp2 = Ambient?
Temp3 = ??? Why is it so high?
Temp: = ?
HD01 and HD02 I can figure out myself
Temp1 = ?
If anyone could help it would be appreciated
Go into the config part of Speedfan and look at what sensors are feeding data to the respective temps, you most likely are seeing the GPU temp and the vid card ambient temp on two of those. As to the insanely high temp, you're likely seeing a reading from what Speedfan sees as a sensor but it's not actually there.
Good luck!
