Need help with Silverstone ST85-F
sabregen
Recently bought here on the forums. Came with PP05 short set + all the other cables, and maybe a few from another SS PSU, too (from the seller). The specs say it can do 2x 8pin PCI-E, which I have found the cables for... or 4x 6pin PCI-E. I currently have a 5850 running off of both of the PCI-E ports on the PSU, but don't know which cables I would need to get the 4x 6pin PCI-E capability out of the PSU.
Can anyone help with this? That is issue #1
Second question is what is the 6pin Aux port for?
Thanks.
Did the PSU come with any cables that had two PCI-E power connectors on each? I presume that would be how to get four PCI-E power connectors out of it.
How many PCI-E cables did it come with? I assume the 2 8pin PCI-E cables you found are 6+2pin cables, so there should be 2 more 6pin PCI-E cables there if the specs say there are 4 6pin PCI-E (those two 8pin cables would count as two of the 4 6pin PCI-E). If not, then there's something missing.
