Need help with setting up Vista 64bit
Diablo2K
i am trying to get F@H working on my computer, the one in the sig. The program will not automaticly start on its own, I have to start them manually. here is the error I am getting. both instsances are getting the same error. not sure how to get this working automaticly, I am trying to get back into folding, I am even building a second computer that will be doing nothing but folding. I have some quistions there also but those can wait till at least I get the box finished.
Code:
[14:03:16] Configuring Folding@Home...
Opening Service Manager failed (5)
Windows denied access for this operation.
You must be logged on with Administrator privileges.
The program will continue now without having installed itself as a service.
You may bring up this Configuration later by starting the program with
the -configonly flag.
[14:04:07] - Ask before connecting: No
[14:04:07] - Use IE connection settings: Yes
[14:04:07] - User name: Diablo2k (Team 33)
[14:04:07] - User ID: 71C7A748424A9517
[14:04:07] - Machine ID: 2
[14:04:07]
[14:04:07] Work directory not found. Creating...
[14:04:07] Could not open work queue, generating new queue...
[14:04:07] + Benchmarking ...
[14:04:09] - Preparing to get new work unit...
[14:04:09] + Attempting to get work packet
[14:04:09] - Connecting to assignment server
[14:04:10] - Successful: assigned to (171.64.65.65).
[14:04:10] + News From Folding@Home: Welcome to Folding@Home
[14:04:10] Loaded queue successfully.
[14:04:26] + Closed connections
[14:04:26]
[14:04:26] + Processing work unit
[14:04:26] Core required: FahCore_78.exe
[14:04:26] Core not found.
[14:04:26] - Core is not present or corrupted.
[14:04:26] - Attempting to download new core...
[14:04:26] + Downloading new core: FahCore_78.exe
[14:04:26] + 10240 bytes downloaded
[14:04:26] + 20480 bytes downloaded
[14:04:26] + 30720 bytes downloaded
[14:04:26] + 40960 bytes downloaded
[14:04:26] + 51200 bytes downloaded
[14:04:26] + 61440 bytes downloaded
[14:04:26] + 71680 bytes downloaded
[14:04:26] + 81920 bytes downloaded
[14:04:26] + 92160 bytes downloaded
[14:04:26] + 102400 bytes downloaded
[14:04:26] + 112640 bytes downloaded
[14:04:26] + 122880 bytes downloaded
[14:04:26] + 133120 bytes downloaded
[14:04:26] + 143360 bytes downloaded
[14:04:26] + 153600 bytes downloaded
[14:04:26] + 163840 bytes downloaded
[14:04:26] + 174080 bytes downloaded
[14:04:26] + 184320 bytes downloaded
[14:04:26] + 194560 bytes downloaded
[14:04:26] + 204800 bytes downloaded
[14:04:26] + 215040 bytes downloaded
[14:04:26] + 225280 bytes downloaded
[14:04:26] + 235520 bytes downloaded
[14:04:26] + 245760 bytes downloaded
[14:04:26] + 256000 bytes downloaded
[14:04:26] + 266240 bytes downloaded
[14:04:26] + 276480 bytes downloaded
[14:04:26] + 286720 bytes downloaded
[14:04:26] + 296960 bytes downloaded
[14:04:26] + 307200 bytes downloaded
[14:04:26] + 317440 bytes downloaded
[14:04:26] + 327680 bytes downloaded
[14:04:26] + 337920 bytes downloaded
[14:04:26] + 348160 bytes downloaded
[14:04:26] + 358400 bytes downloaded
[14:04:26] + 368640 bytes downloaded
[14:04:26] + 378880 bytes downloaded
[14:04:26] + 389120 bytes downloaded
[14:04:26] + 399360 bytes downloaded
[14:04:26] + 409600 bytes downloaded
[14:04:26] + 419840 bytes downloaded
[14:04:26] + 430080 bytes downloaded
[14:04:26] + 440320 bytes downloaded
[14:04:26] + 450560 bytes downloaded
[14:04:26] + 460800 bytes downloaded
[14:04:26] + 471040 bytes downloaded
[14:04:26] + 481280 bytes downloaded
[14:04:26] + 491520 bytes downloaded
[14:04:26] + 501760 bytes downloaded
[14:04:26] + 512000 bytes downloaded
[14:04:26] + 522240 bytes downloaded
[14:04:26] + 532480 bytes downloaded
[14:04:26] + 542720 bytes downloaded
[14:04:26] + 552960 bytes downloaded
[14:04:26] + 563200 bytes downloaded
[14:04:26] + 573440 bytes downloaded
[14:04:26] + 583680 bytes downloaded
[14:04:26] + 593920 bytes downloaded
[14:04:26] + 604160 bytes downloaded
[14:04:26] + 614400 bytes downloaded
[14:04:26] + 624640 bytes downloaded
[14:04:26] + 634880 bytes downloaded
[14:04:26] + 645120 bytes downloaded
[14:04:26] + 655360 bytes downloaded
[14:04:26] + 665600 bytes downloaded
[14:04:26] + 675840 bytes downloaded
[14:04:26] + 686080 bytes downloaded
[14:04:26] + 696320 bytes downloaded
[14:04:26] + 706560 bytes downloaded
[14:04:26] + 716800 bytes downloaded
[14:04:26] + 727040 bytes downloaded
[14:04:26] + 737280 bytes downloaded
[14:04:26] + 747520 bytes downloaded
[14:04:26] + 757760 bytes downloaded
[14:04:26] + 768000 bytes downloaded
[14:04:26] + 778240 bytes downloaded
[14:04:26] + 788480 bytes downloaded
[14:04:26] + 798720 bytes downloaded
[14:04:26] + 808960 bytes downloaded
[14:04:26] + 819200 bytes downloaded
[14:04:26] + 825633 bytes downloaded
[14:04:26] Verifying core Core_78.fah...
[14:04:26] Signature is VALID
[14:04:26]
[14:04:26] Trying to unzip core FahCore_78.exe
[14:04:26] Decompressed FahCore_78.exe (2338816 bytes) successfully
[14:04:26] + Core successfully engaged
[14:04:31]
[14:04:31] + Processing work unit
[14:04:31] Core required: FahCore_78.exe
[14:04:31] Core found.
[14:04:31] Working on Unit 01 [May 21 14:04:31]
[14:04:31] + Working ...
[14:04:31]
[14:04:31] *------------------------------*
[14:04:31] Folding@Home Gromacs Core
[14:04:31] Version 1.90 (March 8, 2006)
[14:04:31]
[14:04:31] Preparing to commence simulation
[14:04:31] - Looking at optimizations...
[14:04:31] - Created dyn
[14:04:31] - Files status OK
[14:04:48] - Expanded 3634619 -> 18750173 (decompressed 515.8 percent)
[14:04:49] - Starting from initial work packet
[14:04:49]
[14:04:49] Project: 2620 (Run 75, Clone 84, Gen 20)
[14:04:49]
[14:04:54] Assembly optimizations on if available.
[14:04:54] Entering M.D.
[14:05:02] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[14:05:02]
[14:05:02] Writing local files
[14:05:06] Extra SSE boost OK.
[14:05:07] Writing local files
[14:05:07] Completed 0 out of 125000 steps  (0)
[14:19:19] Writing local files
[14:19:20] Completed 1250 out of 125000 steps  (1)
[14:33:10] Writing local files
[14:33:10] Completed 2500 out of 125000 steps  (2)
[14:46:59] Writing local files
[14:46:59] Completed 3750 out of 125000 steps  (3)
[15:00:49] Writing local files
[15:00:49] Completed 5000 out of 125000 steps  (4)
[15:14:40] Writing local files
[15:14:40] Completed 6250 out of 125000 steps  (5)
[15:28:30] Writing local files
[15:28:30] Completed 7500 out of 125000 steps  (6)
[15:42:20] Writing local files
[15:42:20] Completed 8750 out of 125000 steps  (7)
[15:56:11] Writing local files
[15:56:11] Completed 10000 out of 125000 steps  (8)
[16:10:01] Writing local files
[16:10:01] Completed 11250 out of 125000 steps  (9)
[16:23:26] Writing local files
[16:23:26] Completed 12500 out of 125000 steps  (10)
[16:37:17] Writing local files
[16:37:17] Completed 13750 out of 125000 steps  (11)
[16:51:07] Writing local files
[16:51:08] Completed 15000 out of 125000 steps  (12)
[17:04:57] Writing local files
[17:04:57] Completed 16250 out of 125000 steps  (13)
[17:18:47] Writing local files
[17:18:48] Completed 17500 out of 125000 steps  (14)
[17:32:13] Writing local files
[17:32:13] Completed 18750 out of 125000 steps  (15)
[17:46:04] Writing local files
[17:46:04] Completed 20000 out of 125000 steps  (16)
[17:59:55] Writing local files
[17:59:55] Completed 21250 out of 125000 steps  (17)
[18:13:57] Writing local files
[18:13:57] Completed 22500 out of 125000 steps  (18)
[18:27:47] Writing local files
[18:27:47] Completed 23750 out of 125000 steps  (19)
[18:41:38] Writing local files
[18:41:38] Completed 25000 out of 125000 steps  (20)
[18:55:28] Writing local files
[18:55:28] Completed 26250 out of 125000 steps  (21)
[19:09:18] Writing local files
[19:09:18] Completed 27500 out of 125000 steps  (22)
[19:23:09] Writing local files
[19:23:09] Completed 28750 out of 125000 steps  (23)
[19:36:59] Writing local files
[19:36:59] Completed 30000 out of 125000 steps  (24)
[19:50:49] Writing local files
[19:50:49] Completed 31250 out of 125000 steps  (25)
[20:04:39] Writing local files
[20:04:39] Completed 32500 out of 125000 steps  (26)
[20:18:29] Writing local files
[20:18:29] Completed 33750 out of 125000 steps  (27)
[20:32:20] Writing local files
[20:32:20] Completed 35000 out of 125000 steps  (28)
[20:44:27] Writing local files
[20:44:27] Completed 36250 out of 125000 steps  (29)
Folding@Home Client Shutdown.
--- Opening Log file [May 28 21:48:10]
# Windows Console Edition #####################################################
                       Folding@Home Client Version 5.04beta
                          http://folding.stanford.edu
Launch directory: C:\fold 2
Executable: C:\fold 2\FAH504-Console.exe
[21:48:10] - Ask before connecting: No
[21:48:10] - Use IE connection settings: Yes
[21:48:10] - User name: Diablo2k (Team 33)
[21:48:10] - User ID: 71C7A748424A9517
[21:48:10] - Machine ID: 2
[21:48:10]
[21:48:10] Loaded queue successfully.
[21:48:10] + Benchmarking ...
[21:48:14]
[21:48:14] + Processing work unit
[21:48:14] Core required: FahCore_78.exe
[21:48:14] Core found.
[21:48:14] Working on Unit 01 [May 28 21:48:14]
[21:48:14] + Working ...
[21:48:14]
[21:48:14] *------------------------------*
[21:48:14] Folding@Home Gromacs Core
[21:48:14] Version 1.90 (March 8, 2006)
[21:48:14]
[21:48:14] Preparing to commence simulation
[21:48:14] - Looking at optimizations...
[21:48:14] - Files status OK
[21:48:18] - Expanded 3634619 -> 18750173 (decompressed 515.8 percent)
[21:48:18]
[21:48:18] Project: 2620 (Run 75, Clone 84, Gen 20)
[21:48:18]
[21:48:19] Assembly optimizations on if available.
[21:48:19] Entering M.D.
--- Opening Log file [May 28 21:51:10]
[21:51:10] - Ask before connecting: No
[21:51:10] - Use IE connection settings: Yes
[21:51:10] - User name: Diablo2k (Team 33)
[21:51:10] - User ID: 71C7A748424A9517
[21:51:10] - Machine ID: 2
[21:51:10]
[21:51:10] Loaded queue successfully.
[21:51:10] + Benchmarking ...
[21:51:12]
[21:51:12] + Processing work unit
[21:51:12] Core required: FahCore_78.exe
[21:51:12] Core found.
[21:51:12] Working on Unit 01 [May 28 21:51:12]
[21:51:12] + Working ...
[21:51:12]
[21:51:12] *------------------------------*
[21:51:12] Folding@Home Gromacs Core
[21:51:12] Version 1.90 (March 8, 2006)
[21:51:12]
[21:51:12] Preparing to commence simulation
[21:51:12] - Looking at optimizations...
[21:51:12] - Files status OK
[21:51:17] - Expanded 3634619 -> 18750173 (decompressed 515.8 percent)
[21:51:18]
[21:51:18] Project: 2620 (Run 75, Clone 84, Gen 20)
[21:51:18]
[21:51:18] Assembly optimizations on if available.
[21:51:18] Entering M.D.
[21:51:40] (Starting from checkpoint)
[21:51:40] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[21:51:40]
[21:51:40] Writing local files
[21:51:40] Completed 36250 out of 125000 steps  (29)
[21:51:45] Extra SSE boost OK.
[21:53:05]
--- Opening Log file [May 28 21:55:08]
[21:55:08] Configuring Folding@Home...
[21:55:45] - Ask before connecting: No
[21:55:45] - User name: Diablo2k (Team 33)
[21:55:45] - User ID: 71C7A748424A9517
[21:55:45] - Machine ID: 2
[21:55:45]
[21:55:45] Loaded queue successfully.
[21:55:45] + Benchmarking ...
[21:55:47]
[21:55:47] + Processing work unit
[21:55:47] Core required: FahCore_78.exe
[21:55:47] Core found.
[21:55:47] Working on Unit 01 [May 28 21:55:47]
[21:55:47] + Working ...
[21:55:48]
[21:55:48] *------------------------------*
[21:55:48] Folding@Home Gromacs Core
[21:55:48] Version 1.90 (March 8, 2006)
[21:55:48]
[21:55:48] Preparing to commence simulation
[21:55:48] - Looking at optimizations...
[21:55:48] - Files status OK
[21:55:52] - Expanded 3634619 -> 18750173 (decompressed 515.8 percent)
[21:55:52]
[21:55:52] Project: 2620 (Run 75, Clone 84, Gen 20)
[21:55:52]
[21:55:54] Assembly optimizations on if available.
[21:55:54] Entering M.D.
[21:56:16] (Starting from checkpoint)
[21:56:16] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[21:56:16]
[21:56:16] Writing local files
[21:56:16] Completed 36250 out of 125000 steps  (29)
[21:56:20] Extra SSE boost OK.
[22:10:50] Writing local files
[22:10:50] Completed 37500 out of 125000 steps  (30)
[22:23:47] Writing local files
[22:23:47] Completed 38750 out of 125000 steps  (31)
Are you trying to get the console client going or is this the SMP client? I have a go to guide written by Wharf Rat having to do with the SMP. But this looks like a different type of thing. Here is a link to the how to I referred to in case it might help.
You're getting a permissions error while attempting to install as a service. You need to do this with administrator privileges. Otherwise it appears that you're doing it right.
Its running project 2620, so its the console client.
Got it working?
Other things to look at:
turn off "Use IE connection settings: Yes" and change it to "No."
Got it working?
I deleted the .cfg files and redid all the settings and I did select no to the IE settings. I dont know why that one was set to yes.
Its working very well on my system now, FAHSpy is reporting about 600+ points per day. I dont know if thats good or not for only 2 cores. I bought the 4600 as a temp place holder till I can aford something better. I think I will probably get a quad core when they have a 3ghz version under $200. I dont really like overclocking but if they can get a working version of AOD I would probably be more into overclocking.
Have you considered running the SMP client on your dual AMD system?
You would get more points per day (PPD).
Right now I am a noob when it comes to this. I thought the console was the best for me. I have no idea really what all the differant versions are. I know theres the console version, and the graphical version.
This system is not a dedicated folding machine, I still play games and surf. so whatever version is best for me at this time I will be more than happy to learn what I need to get it done, so feel free to sugggest what ever is best. I aint doing this for fame , I am just trying to help out the best I can.
SMP (symmetric multiprocessing) is another console version that supports multicore processor code. i run this one on 2 dual core AMDs and 2x on my quad core. in day-to-day use, I can leave it on and not notice any difference in my machine performance. during things like games, i simply turn it off while I'm gaming.
these clients are available here
I personally run all 5.91 beta6 clients, but i'm sure some folks around here could help setup the newer versions of the smp client if you need help
<-- first go at the red :D
Vista 64 bit only works on the 5.91 beta6 client. 5.92 does not support 64 bit. Just in case you are thinking of going that route.
Ok, So what is the best way of uninstalling the 2 console versions I have now?
Ok, I went into services and disabled the 2 F@H services so they wouldn't start anymore.
Ran the installer for the SMP client (5.91 beta6). Read the directions. Run Install.bat and get this!
What am I doing wrong.
To install the first console I created an account called Superadmin that had a password so I could get the services installed. This worked fine for that, but I cant get the SMP client to work. My normal account that i use everyday is called Diablo2k and does not have a password.
Just hit enter rather than typing in the username.
Tried that still got the same error. I tried installing .net 2.0 it wouldn't let me. Don't know what I am doing wrong. starting to piss me off :)
Where are you trying to install it to? If you have UAC turned on, you shouldn't install in Program Files.
And .Net 2.0 comes with Vista, no need to install.
I just installed it to the default location. its installed in Program files (x86) if thats not the correct location where should I move it to? or do I need to uninstall it then install it to a differant location.
Thanks for all the help! I just want to do my part here.
I have it running fine on Vista 64, but you need to install it in another directory. Program Files (x86) just doesn't seem to work properly.
I installed to c:\fah1 and c:\fah2
I have simply copied fah directories after installing and it's worked fine, but YMMV.
I am really sorry people, I cant get it running, I tried running it from a differant folder, running it for this user only, running it for all users, I keep getting the same error. I am about to give up and just run the old console version.
