Blackhawk05
- Mar 21, 2005
I finally got my sb audigy 2 today. Its an oem, so it only came with the install cd, no bigge.
So I uninstall my old drivers, restart, disable onboard in bios, start cd, and it says my hardwar is not found.
Since there was no manual, I downloaded one thinking I might have forgot a step. Turns out I did. A calble going from the card to the cd-rom was not in. So I got the right cable and plugged it in the the right slockets lining up pin 1.
Restarted, installed drivers, still wont find it.
I downloaded the newest drivers from the creative site, installed, and got the same thing
What is wrong? Help will be greatly appreciated.
Manual for Audigy 2: http://us.creative.com/support/downloads/download.asp
Card: http://us.creative.com/products/product.asp?category=1&subcategory=204&product=10653
Iam gonna go re-check all connections, but I am pretty sure they are good. Maybe I did not put it into the pci slot snug enough?
Ok, the aux_in was in the wrong connector! That should fix it! Wrong
It still does not work. Could it possibly be the pci slot? Gonna go mess around in windows now to see if i can find out any info.
