I would like to know if it's possible to connect two subnets with two routers. The first router is a WRT54GL flashed to DD-WRT v24-sp1 (07-27-08), and the other is a Netgear WNDR3700v2 running 1.0.0.8 which is Open-WRT Kamikaze.
I found many forum posts and tried to follow them but could not get the secondary router and clients to access the internet.
So the setup goes like this:
ISP modem > WAN port of WNDR3700 (192.168.1.1) > LAN TO WAN on the WRT54GL (192.168.2.1)
And then there are clients behind the WNDR3700 as well as behind the WRT54GL.
So from following a bunch of things I found online, I went into the WRT54GL (192.168.2.1) and setup the WAN settings to be static and inputted the following:
WAN on WRT54GL:
IP: 192.168.1.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.1.1
Static DNS 1-3: 0.0.0.0
Then in the "Network Setup" portion of the WRT54GL (192.168.2.1):
Local IP Address: 192.168.2.1
Gateway: 192.168.2.1
Local DNS: 192.168.2.1
From there I found severa posts that said I needed to then go into the Netgear WNDR3700v2 and create a static route which entailed the following settings:
Router Name: Router2
Active: Yes (check box)
Destination IP Address: 192.168.2.0
IP Subnet Mask: 255.255.255.0
Gateway IP Address: 192.168.1.2
Metric: 2
Upon doing this I went ahead and reset both routers by unplugging the power and letting them power cycle.
At this point and time I can now ping between the two subnets without any problems. However, the 192.168.2.1 (WRT54GL) clients cannot get to the internet.
The only other weird thing is that if I type in the WAN setup of the WRT54GL DNS: 192.168.1.1 I can then tracert from the WRT54GL to the WNDR3700 but after the it tries to leave the WNDR3700 it just dies as though it can't figure out how to route it past the WNDR3700.
My entire goal is to subnet the network so that I can have several VM running Server 2008 R2 which will be used for lab purposes and what the Server 2008 needs to simulate is it doing complete DHCP and DNS services for any and all clients that will be connecting to those VMs.
Is it even possible to route traffic both ways between two subnets with two routers running DD-WRT or Open-WRT?
WAN on WRT54GL:
IP: 192.168.1.2
Metric: 2
