Folks,
I used to have a linksys router at home (G portable router)
THe range was not sufficient at home and hence switched to a Buffalo WZR2-G300N router from their N-finiti series.
Used to connect to my sons schools website and to check on his grades and school boards with out any problems on the linksys.
After I switched to the buffalo,
I try to log in to his school website.
Log in is pretty fast, and the first screen opens up real fast. There after nothing else opens up, it just tries for a long time and then gives up.
I use IE7. Switched the browser to firefox and the same problem.
If I bypass the router and connect directly to the comcast modem, I have no problem logging in and looking at all aspects of the boards.
But when I go back via the router, same problem. Super fast log in and then IE error saying web site cannot be found after about 4-5 minutes.
I like the range on the buffalo router.
Is there a solution for this.
Do I need to confgure the buffalo router in any other way.
Anyhelp in this regard would be appreciated.
Been getting a hard time from SO as she's not able to monitor his boards and keep track of whats going on at school.
Experts any suggestions.
His school boards are secure log in.
