Need help with removing old solder, replaceming broken power jack
iceredwing
Basically my problem is that the soldering material that dell uses on the board is very little. I was able to remove the ones that had a decent amount of solder applied which were the ones on the sides.
The gold pins on the center and back of the power jack were the ones that were very hard to remove. I googled some tips, and someone stated to use wire cutters to remove the power jack and it will become easier to remove the old solder since you can attempt it from either the top or bottom.
Unfortunately for me that doesn't hold true. I just can't soften up the old solder because the soldering tip I have seems to be too big to actually reach the solder, I end up heating up the pins and the transfer of heat to the solder isn't enough. Also for the record, I am using a fine tipped soldering iron... i'm unsure if I can find anything smaller
I tried apply new solder over the old one. But the old solder still doesn't soft up with the new one.
Does anyone have any tips or suggestion? If a picture of the holes is needed, I will disassemble it and take some. But hopefully someone has attempted to fix the recent dell power jacks (cause I know they have changed) and you can tell me how you got it out.
The board itself still works, and I'm currently powering the laptop via replicator. So hopefully that is an indication that nothing is broken
Pix might help, since (on rare occasion) laptops will have a layer of annoying glue on top of solder for high-stress components like power/ethernet/usb ports to strengthen the bond
