Hi all,
I recently upgraded my computer and everything was going good till I flashed the motherboard with a new bios and now the monitor randomly goes black anywhere from boot up, a few minutes after getting into windows 7, to several hours even though it's still getting a video signal using the igpu. I had previously had my discrete video card in it and it worked but whenever I would go to play games it would cause my computer to hard freeze and I'd have to reset my computer so I switched to the onboard igpu. I'm not sure where to put this so I put this here. The specs are listed below and any and all help would be appreciated.
Mobo: Asus p8h67-m evo b3 (bios 2103)
Cpu: Intel Core i3-2120 @ Stock
Ram: G.Skill Ripjaws X 8gb @1333
HD: Seagate Barracuda 500 gb
PSU: Corsair cx400 400w
Case: Ultra Microfly matx (Crappy but i'll be upgrading soon)
OS: Windows 7 Ultimate x64
P.S. - I ran intelburn test and memtest x86 and there was no problems with the ram. The temps usually stay around 20-30 degrees idle and around 40-50 degrees under full load. I think it might be the psu but not sure because I don't currently have access to another one to test it out. Thanks in advance. I also wanted to mention that I've reset cmos, tried the c.p.r. (cpu parameter recall) to see if those would help but they didn't.
