[System Information]
Microsoft Windows 98 4.10.2222 A
Clean install using Select CD /T:C:\WININST0.400 /SrcDir=F:\WIN98SE /IZ /IS /IQ /IT /II /NR /II /C /U:xxxxxxxxxxxxxxxxx
IE 5 6.0.2800.1106
Uptime: 0:00:05:45
Normal mode
On "NA" as ""
AuthenticAMD AMD Athlon(tm) XP 2000+
512MB RAM
51% system resources free
Windows-managed swap file on drive C (405MB free)
Available space on drive C: 405MB of 9756MB (FAT32)
Available space on drive D: 35173MB of 57241MB (FAT32)
(9 fans)
10 GB hard drive Seagate
60 Gb hard drive Maxtor
Burner
Dvd Drive
My problem is that occasionally a hard drive seems to audibly click off then the system crashes. I do not have any power saving features activated. My boot drive is drive C. I believe drive C is the problem drive. When I reboot Ctrl+Alt+DEl I get invalid system disk error on POST. So I turnde everything off then back on again. And the system disk error goes away. The Maxtor seems hotter to the touch than the Seagate so I recently turned on the 4 fans for C: and D: drives. It seems I have had this problem in the past when combing C: and D: drives together. But when C: is alone it seems it never has this problem. Does anyone know what might being giving this problem? Right now both drives are running fine with no crashes on either. I was thinking maybe my C: drive is beginning to crash and burn out. And showing signs of that maybe. Scandisk typically goes on but shows no errors. Thanks for reading.
IE 5 6.0.2800.1106
Uptime: 0:00:05:45
Normal mode
On "NA" as ""
512MB RAM
(9 fans)
Burner
Dvd Drive
