Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey guys wondering if you can help me out with a xbox
HDD i purchased I guess it is locked, and I need it unlocked
for I can use it one a PC, and need to know how to unlock,
thanks.
Crap I just sold an old XBox hard drive to someone - and I never unlocked it. I dunno what unlocking even is. You can't just format it? I know there are unlocking/locking programs that work on the XBox - most likely there are ways to do it from a PC as well. I bet you'll get much more helpful answers on forums.xbox-scene.com.
I do have MSN, but I'm going to exchange
the drive for one that works, it just dosen't
seems to be worth the efort, but thanks
for the help any way, but if for some reason
I can't i'll give you a call.
