Namelessme
- Jan 3, 2012
Hello,
I recently purchased a decent condition NEC FE2111 from someone on Craig's list, but need some help getting it set up correctly. My main problem is getting my computer to play nice with a CRT.
To confuse matters, my computer is a mac mini (2011) (w/Lion and Windows 7 installed) using a mini display to VGA adapter, which may cause some problems on its own.
Key problems so far:
During initial boot sequence, the Win 7 logo doesn't appear. Instead all I get is a black screen, then the log-on screen pops up. Not a major, major issue, but if I ever need to go into safe mode, I'll just be guessing at what I am clicking... can't see anything.
Second issue is that my computer thinks my CRT is a LCD, with a native res of 1600x1200. I tried updating the drivers (Intel 3000HD), but it didn't help. I strangely have the choices of 800x600, 1024x768 and 1600x1200 in which to use display scaling. All other options can either be centered (squashed) or stretched (blurry... not good).
The monitor can go up to 1920x1440, and can do much higher refresh rates than my computer is currently allowing me to do. To be honest, I probably won't be running it at super high resolutions or refresh rates anyway, but I'd at least like to be able to use 1152x864 without any resizing weirdness.
When I first hooked up the monitor, win 7 chose a generic non-plug and play driver for it, and I was able to use any resolution I wanted, no stretching, etc. But Naviset (NEC calibration tool) wouldn't work. I then boot into the Mac side of things, and I guess the Apple EFI got reset, as now Win 7 knows it's a FE2111, and it chooses the generic plug and play driver. Naviset even works now. All good, I thought, until I tried to change the resolutions, and the above sizing/refresh rate issues came into play.
So... any advice suggested? Changing the monitor driver may work, but the NEC one doesn't seem to be compatible with Win 7. Anyone know of a newer driver out there? I found someone here in these forums who made a Vista X64 driver for said monitor, but would that work in Win7? Or could it possibly just cause more problems?
