Need help with my Westy 37"
Aldur
I just bought a westinghouse 37" about 3 weeks ago and the picture quality is superb. I have my 360 put into the vga port and all I have to say that this is the best gaming TV ever! :D My only complaint is, there is only one vga port. :mad: I really want to hook my regular xbox up since its modded and can upscale dvd movies to 720p. But it is such a pain in the ass to go behind the tv and switch cables every time I want to watch a movie. :mad: So I found out that my DVI ports are DVI-i, which means that they will accept digital and analog signals. So i figured that I could plug my xbox into one of them using a vga to DVI adapter. When I did that I got a no signal message on my TV. I called up westinghouse and they basically had no idea what was going on, all they could do is confirm that I have DVI-i ports.
Can somebody help me out, what am I doing wrong here?? :confused:
Just plug the X-Box into a component input, its the same picture quality. VGA just has extra pins for 2-way comunication with the video card.
I agree with using component but if you really want to use vga get a vga switch box of like cyberguys.com or something where you can switch between multiple vga connections with a flip of a switch.
I thought the xbox only did 480p w/ the VGA mod? When did this change?
when modded you can have a upscaler put on the xbox and so movies are upscaled to 720p.
I would just use component cables with the xbox but I see a good amount of ghosting with dvd playback. I've used 4 different brands of cables and so I do not think it is the cables. When I hook up the xbox to the vga port I get a great picture with no ghosting. The tv has 2 DVI-i ports and one vga and so I'd like to use on of those DVI-i ports. A vga switch box is a good idea but Im afraid of losing some of the signial quality.
