Need help with my shuttle
Shainz
Hey guys,
I have the following (copied from invoice)
CPU INTEL CELERON 2.40G 478P 320 RT
DDRAM 256M|PC-3200 991092 MUSHKIN R
HD 40GB|MAXTOR 6E040L0 72R ATA133 %
CDRW LTON|52X32X52 SOHR-5238S BLK R
BRBN PC SHUTTLE MODEL SB65G2 RT
I put it together and installed Windows XP on it. After that I touched it and it was insanely hot. I turned it off and today tried it again after playing around with cooling. The computer loaded up and got stuck on the Win XP Pro Boot Logo with the little bar on the bottom in the middle after crossing about 3 times. I tried reseting the bios and pulling the CMOS battery. After I took out the battery, it wont turn on or anything. Any clue on what to do? Could I have damaged something by possibly overheating it?
this may be dumb but im just makeing shure to help u out u siad u pulled the battery u also have to move the jumper over and power it on once u do that u wont get anything then power it off and put the jumper back and reinstall the battery is that what u did and its not working or have u not put the battery back yet cuz if u did thoes 2 steps itl power on but u wont get anything
