Harlequin76
- Sep 22, 2011
Finally I got my rig built tested primed and all the heavy duty tests were done.
the computer didnt fail in any, but I still want to know if I got this right.
(didn't save pictures of the prime testing and so on ><" forgot)
Anyway I listened to the guys here about OC , soI didn't want to pass the 1.35v core voltage so I tweaked and got this:
i5 2500k@ 4.5ghz
Uploaded with ImageShack.us
Temps I see now:
I am trying with the Asus AI suite II to control my H80 fans, but they seem to ignore me and stay on 2000-2100 RPM.
I am not sure if to be happy with results or not, when I played Heroes of Newerth Highest settings GPU reached 50c(21% fan) and CPU reached 57-60.
I thought the h80 would get better results
here is a picture of the inside of the case:
I have 2 1850 gentle tyhpoons , all i think i need to do is open bot panels of case remove angled fan, remove bottom fan, put typhoon, remove h80 , put typhoon, connect h80 , connect typhoons to motherboard(good idea?)
anyway what do you think?
Thanks!
Harelquin76
i5 2500k@ 4.5ghz
Temps I see now:
Thanks!
Harelquin76
