Need help with my first build
tmdg
I'm building a computer for the first time and I need some guidance.
Gaming (mostly Starcraft 2), Coding, Web Browsing
around $1000 total, don't mind spending a bit more if it's worth it
3) Where do you live?
San Francisco Bay Area
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need everything to build a computer except for a monitor, keyboard, mouse, and speakers. Please let me know what that is :)
Monitor (20 in. Dell), keyboard, mouse, speakers
6) Will you be overclocking?
Probably not
20 in.
Within the next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I'm not sure... any advice?
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
No, I will probably want to get Windows 7
Besides StarCraft 2, are there any other games that you want to play?
How old is the monitor you're currently using? Which resolution do you use? Are you planning on buying a new one any time soon (like, within the next 12 months)?
Do you want this system to be designed more for gaming or coding?
Have you performed an in-forum search of recent build threads of $1000-or-less systems?
Other games I might play: Heroes of Newerth, Diablo 3 when it comes out
My monitor is about 6 years old. I run it at 1600x1200 resolution. There's a good chance I might buy a new one in the next 12 months.
I'd like it more designed toward gaming.
I have searched a bit and found some posts, but since I don't really know what I'm doing, I thought I'd make a post to get specific recommendations for my situation.
Thanks for your help!
Thanks for your help. Really appreciate it! I'm wondering if my money would be better spent on the SSD or on a better video card (maybe 5850?) if I want to optimize performance in game. What is the use case when SSD would be the better option?
Between the SSD and the video card, the video card would offer more of an improvement in gaming. The SSD loads the game faster, but it doesn't improve upon the frame rates while gaming. The video card allows for smoother gameplay at higher resolutions. However, with a 1600x1200 resolution, the HD5850 is overkill for the most part.
