Hi all
I am going to be buying a Lian Li 343B for a new water cooled system. Basically i need help with the looping and the extra parts needed. I will be cooling one processor and 2 8800 GTS's with a view to cool the ram with water at a much later date so ignore that for now.
I have read so many different ways to do things and it just confuses the hell out of me until i can see something on paper.
What i have got so far is this
Laing D5-Vario (1/2") - £57.87
D-TEK FuZion CPU Block - £33.18
EK-FC8800 8800 GTS - x 2 - £103.98
Masterkleer General Purpose Clear PVC Tubing
Danger Den Clear Dual Bay Reservoir - 2x5.25" - - £22.68 (Subject to Change)
HWLabs Black Ice Stealth GT360 (Black) x2 - £75.94
Yate Loon Medium Speed Fan: D12SM-12 x 3 - £13.47
Nylon Hose Clamps 16mm - 19mm x 10 - £4.90
Arctic Silver 5 - £4.69
Fluid XP+ Ultra Midnight Blue - 1 Litre - £22.99
Lian Li 343B Case - £220
Sound Proofing - £34.08
Now the models i have come up with so far are these
Lol, excuse the crudeness but im not really an AutoCad person
Thats all i have so far but how the hell do i go about it... with splitters and Y fittings or something? Any help would be greatly appriciated and feel free to rip this apart, call me a noob and suggest something better. The case gives me plenty of room to move about so space is no problem. I much prefer the idea of having a seperate loop for the cpu and the two gpu's by the way, but not sure if that is the way it should be done. Also people say to test the pump for a while before putting it into the system. I presume that is done by using a seperate PSU (for a 12v DC) and linking it all up outside the case? One last thing, i am worried about the bleeding part...having the processor with nothing on it to take heat away for even the smallest time worries me, put my mind at rest please
So i will leave you to ponder if you will and any help as i say will be most appreiciated.
Thanks all
Drec
Thanks all
Drec
