need help with missing hard drive problem
Xiphos
so I have 2 hard drives of the same model
one of them I have been using just fine, so recently I decided it was time for a fresh install of Vista, and I opted to install in AHCI mode this time.
I was one of the early adopters, so I have Vista disk w/o SP1
when I got done installing, everything seems fine, hard drives shows up.
so I went ahead and installed SP1
after restart, my hard drive went missing. :confused:
so I plugged in another fresh drive of the same model, just to make sure it is not dead.
the fresh drive has the same problem too.
here is all 3 of my hard drives showing up in BIOS
and here is the fresh drive with unallocated space showing up
formatting....
after about 30 seconds
gone, just like that.
hardware:
Mobo: Asus P5Q Pro Bios - 2102
Hard Drive: WD4000YR-01PLB0
software:
Vista home premium 64 bit
I've installed
- Intel(R) P45/ICH10R Chipset Software Installation Utility WHQL V9.0.0.1009
- Marvell 88SE6111 SATA Controller Driver V1.2.0.60
but didn't work.
seems like I have 2 options, format and run in EIDE mode, or again, format and do w/o SP1
