FireStormGS
- Jul 24, 2001
I'm working on a project where I need a computer running matlab to communicate with a PLC controller. Right now I have a usb -> serial converter and the end of the serial cable is cut open with all of the wires exposed. I need to be able to control the outputs on 3 of the serial cable wires from 0 to 5V. The problem is that normal serial communication only sends data on 1 pin. I need to know if it possible to override the normal serial communication commands and directly control the voltage on certain pins. If this is not possible I suppose I will have to switch to a parallel cable.
